In a nutshell, I like information. When I first got my Class B, the initial trip was towing cross country, with mountain passes. It made me nervous to just see the Ford needle engine temperature gauge sitting there, as usual, in the "good" range. Was it really good? Why did it not move? Was it going to stay good but then suddenly fly up into the hot range with no warning? And what about the transmission? What temperature was that running at? What if I was towing in Overdrive - how would that affect it? And just where were those RPM's on my way up steep passes? Best to keep them up to avoid lugging.
If you have a 1997 or newer chassis (with Ford vans anyway), you have an OBD II port. This is a small, trapezoidal plug/socket that is at the bottom/front edge of the dashboard, basically right ahead of your knees, in the center below the wheel. The Scan Gauge II plugs into that. It is really plug-and-play -- that simple. You buy it (~$150), plug it in, and suddenly you have a world of information at your fingertips. There are tens of different things you can choose to monitor, and any four can be displayed at one time. There is no learning curve to speak of.
Some examples of choices I routinely monitor (situation dependent):
Engine temperature (this is in degrees F, not a needle!)
Transmission fluid temperature (again, in degrees F)
RPM
Present MPG
Average MPG
Intake air temperature (used this as a thermometer of sorts on my previous rig that did not display outside temp on the mirror, although now I do have outside ambient temperature on the mirror)
Alternator performance (volts) (had an alternator slowly die on me once, years ago, and strand me - I think I would have been able to pick up on it with this gauge).
There are many other choices, and they are easily cycled through.
This device also reads and dismisses (if you choose to) codes. Have a check engine light come on? You can find out what the code number is, Google it to see what it is, and then dismiss it if you choose to (which is not to say that you don't want to repair the issue, but sometimes you want to see if it comes back, such as an evap leak that might just be a loose gas cap, etc.). Or show up at your local repair shop armed with info.
You can also do quite a bit with fuel mileage, fuel average, etc. I sometimes use this in the mountains, because after many ups and downs, sometimes it's hard to tell if I'm climbing or descending on a mild grade. If I see 8mpg, I'm climbing; 25 and I'm descending
RPM's are something most of us don't need to see after we are used to our vehicles, but I do sometimes still like to watch them when towing, as I will downshift manually on or approaching uphill grades, where I can see what is coming before the transmission can (best to keep RPM up in good range, vs. lugging). Also it's not always that easy to hear the engine (radio, fan), and with an automatic not as much "feel" as with a manual.
Transmission temperature: The main reason I bought the gauge. To display this you have to program in a few numbers (it is a free extra "X gauge" function) but this is not hard. If anyone wants a walk through I can give you one. Once it's in your Scan Gauge, you can view it whenever you like. Transmission temperature does vary, and this is very good information to have.
Engine temperature stays pretty constant on the V-10 (was even more constant on my previous V-8 of the same class). So the stock gauge not moving is pretty much "true." It is still nice to monitor it, and when the extra fan comes on it's not such a surprise (No more, "What, is a helicopter landing on me!?"
The look can be customized slightly (background color; brightness) but it's basically what you see is what you get. I have seen some folks mount them on top of the dashboard, just ahead of the top hump of the steering wheel, but that didn't provide good visibliity for me. My first proposed location seemed like it would be great, but the gauge would have been obscured when I put the shift selector in Drive, so that is something to check for.
The Scan Gauge can easily be transferred from vehicle to vehicle (presuming both vehicles are compatible with the gauge).
To "install" the Scan Gauge II there are a couple of options:
1) Velcro, somewhere on or around dashboard
a) They give you a piece of Velcro, but I found that the adhesive gives up the ghost in hot weather.
b) I used a couple of pieces of adhesive "Dual Lock" Velcro-like product instead, and that has held up just great through heat/cold/everything.
The cord comes out the side for options 1 and 2, so you can see it. This doesn't bother me, however...
3) The cord can also be led out the back of the gauge (there is a second socket), so if you wanted to drill a hole for it in the dash, the cord could be completely hidden.
Here is mine in place:
And in use:
a) On a blazing hot day in the desert (sorry about poor photo quality, but it gives you the idea anyway). Here is what it is showing in the above photo, going around clockwise from upper left:
1) Alternator is putting out 13.6 volts
2) Engine cooling water temperature is at 193º
3) Transmission fluid temperature is at 170º
4) Fresh air intake temp is 118º *
*Ambient outside air temp was actually around 108º (man it was hot!). The "Fresh Air Intake" gauge is a reasonable guide to outdoor temps, usually, but not if you have just been stopped, etc. which I think I was in this photo. Once you get out on the highway it is close, although a dedicated outside/ambient thermometer is better for monitoring outside temp.
b) Chugging my way up a steep/long mountain pass, while towing, in the Sierra. Really nice to be able to glance over and see that all is okay with the temps, etc. This is after I installed a larger transmission cooler. It was okay before, but I wanted to keep the transmission temperatures even cooler when towing/hot weather. Here is what it is showing, going clockwise from upper left:
1) Fuel mileage, 4.5 MPG (did I mention it was a really steep grade?)
2) Engine cooling temperature is 198ª
3) Transmission fluid temperature is 158º
4) Engine RPM are 2,734
Here is a link to the company's page for the gauge, and then one to the Scan Gauge II on Amazon. They are also available at Autozone, etc.
http://www.scangauge.com/products/scangaugeii/
http://www.amazon.com/ScanGauge-Automot ... B000AAMY86
