We aim to please!Kirah wrote:This thread is giving me all kinds of ideas for radical remodeling
Oh, btw, I see that "Shelly" looks to have had the roof air conditioner removed, and the resultant hole is covered with something plus some expanding foam. This is probably obvious since the Air-con is not there, but that is a stock ~14" x ~14" hole that takes any normal RV roof vent (the Air-con units are much larger, but the part that projects down through the hole fits the 14" opening).
I removed my Air-con because I don't tend to use it and instead have a skylight there. I really like the natural light that floods in, plus the star views. I kept the hole and the AC wire stub intact so an Air-con could go back if desired. The Concourse windows are tinted/privacy mirrored, which is nice, but the natural skylight light complements it, IMO (I like natural light). I do cover it with Reflectix (on the inside) sometimes when it's hot and the sun is at summer angles, but that wouldn't be necessary with a vent.
If you do have the Air-con AC wire, it likely runs the same as my Concourse. That is that there is a small junction box on the wall just aft of the passenger side window (was in Microwave cabinet) and from there a piece of Romex type wire goes through the roof cavity and comes out on the passenger side of the Air-con hole.
There are (on my Chinook anyway) also DC wires that come in from the other side (from the chase over the couch window they run through the roof cavity to the Air-con hole). Those feed a ceiling light that is between the sink/stove and the couch/dining area, and then go forward to another ceiling light just head of the air-con hole, and then go forward again to power a Fantastic vent in the forwardmost 14" hole right at the front of the roof.
