Here are photos of mine (1999). This is with the front closet wall off. The plywood "shelf" you see is the "roof" of the normal closet. It is carpeted on the underside that faces the closet, and there is a perforated flange on the underside that serves as a closet "rod" (carpet is the white, marine hull liner type carpet they used in many places). This area housed only the generator start panel/hourmeter and the hard-wired CO monitor. Ignore the white "thing" on the left of the first photo; that is the gen start panel that I have in a bag that photobombed.kdarling wrote:Has anyone peeked inside the area above the closet? In newer models, that's where the generator control and CO monitor is. There's nothing in mine, so it hit me that perhaps I could ream out a nice opening to make a tiny shelf for hats, gloves, etc at the rear entrance. Anyone looked there, or have a photo inside?
The rear/outboard corner is where most of the wiring goes up/down after coming "across the great divide" of the rear door. That's why you see so much loom there.
1) "cutaway" overview without front panel on.
2) Same view, but shows detail of aft/outboard.
3) Same view, but shows detail of forward/outboard. The "wall" on the left is the wall that is common with the refrigerator compartment (thread subject tie-in!).
