Page 1 of 2
Replaced the hot water heater
Posted: March 4th, 2015, 3:01 pm
by Manitou
Thanks to my improper winterization, I got to replace the suburban hot water heater with a new one. After looking at the old one closer and closer, it wasn't such a bad thing to replace it.
Getting the outside flange to let go of its glue/silicone and come off was the worst of it.
Re: Replaced the hot water heater
Posted: July 21st, 2015, 12:22 am
by RyanSnyder
Well, I say that this is really a good idea. Right now I am still using my old water heater http://www.bestsellingreviews.com/Home/Water-Heater/. But maybe I could do stuff like this when I need to replace a new one. Thanks!
Posted: July 21st, 2015, 10:02 am
by Manitou
Welcome Ryan. I can't say I would have replaced it before it broke, but since it did break (froze.. Somehow screwed up and didn't get antifreeze into it.. Or at least not enough) I replaced it with new. The old one had seen better days anyway, but I'll drain the tank before I start putting in the pink stuff next time just to be safer now.
Posted: July 21st, 2015, 11:08 am
This is a bit of a spontaneous toss-off, but I bought a brand new Suburban water heater and new door for my Concourse, but have decided to go sans water heater for now. As such, I was just keeping it in the box in storage, ready for that day. But.... maybe I should sell it and then buy another one if/when.
If you are interested, Ryan, just PM me.
Posted: July 21st, 2015, 1:06 pm
by Concourse
The key to winterizing a hot water heater is to shutoff/divert the two water valves on the coach/inside side of the hot water heater and pull the anode rod to drain the water out of the tank.
Posted: July 21st, 2015, 6:02 pm
by Manitou
Do you blow out everything with compressed air or use the pink stuff after that?
Posted: July 22nd, 2015, 7:37 am
by Skillet
Where did you end up purchasing it from? Mine's not looking great and I want to find a good place to keep in my bookmarks when it's time to change it.
Posted: July 22nd, 2015, 9:26 am
I think I either got it from Amazon or maybe Adventure RV. Note that the door/flange are a separate item.
In my rig the water heater is a Suburban SW6D. This is 6-gallon, direct spark ignition (so you can start from inside rig), propane powered. The Suburban SW6DE can also be run on electric power (if plugged in) (with appropriate wiring).
Posted: July 22nd, 2015, 12:28 pm
by Concourse
Manitou wrote:Do you blow out everything with compressed air or use the pink stuff after that?
Pink stuff but not in the hot water heater. I divert the water (two valves), drain tank, and drain the floor valves. Pink stuff is for the Pex lines in the coach and P-traps. If there is no water in the water heater then nothing to freeze and expand.
What broke in your water heater?
Posted: July 22nd, 2015, 12:29 pm
by Concourse
Skillet wrote:Where did you end up purchasing it from? Mine's not looking great and I want to find a good place to keep in my bookmarks when it's time to change it.
That Suburban water heater is super common. The local RV shop near me has 3 in stock and I live in the woods not a city.
