kitchen faucet.
kitchen faucet.
On my Glacier the kitchen faucet is leaking just under the handle. I'm thinking the o ring(s) need to be replaced. However I can not find any info on how to take this moen 87810S Purtouch apart. Any suggestions!
jc&ac
1998 CHINOOK CONCOURSE
Re: kitchen faucet.
Some leaky washer replacement info here if you scroll down to Kitchen & Bar - Maintenance section.
https://www.moen.com/customer-support/f ... leshooting
Also other Moen pages have an exploded parts view. Like here:
https://www.moen.com/support/PureTouch/ ... cet/87810S
Re: kitchen faucet.
Thank u, I found good info on mown site,could now remove old cartridge and found new one at hardware store, faucet working well.
jc&ac
Re: kitchen faucet.
Excellent!!
Thanks for the feedback, and glad that your perseverance paid off.
Do keep or post info on that part. It might help others in the same situation.
Kev
Kev
Re: kitchen faucet.
Oh absolutely! Don't we all know the high-high, followed by the low-low when you find a thread with the EXACT problem you are facing (yay!!!) and then at the end it peters out, or a solution is found but no details given. Augh!!!!! Crushing.kdarling wrote:
Re: kitchen faucet.
Hey all..my 2004 Premier has a kitchen sink faucet with two plastic knobs. It is working fine, but the cap on the hot water knob has lost its "teeth" and come off (part that goes over the screw used to remove it). I went to replace it, thinking it was a typical Phoenix (popular RV brand), but that knob is not the right size. I'll return it to Home Depot...But, before I go hunting blind down the rabbit hole for the correct knob, I am hoping someone here knows the brand, make and model of our dual handled faucets. Any and all assistance greatly appreciated.
Thanks
Thanks
Re: kitchen faucet.
Can't you put epoxy glue or crazy glue on it to give it more "bite" while you looking for the perfect knob? It is usually hard to get replacement part for faucet unless it is a major brand.
Re: kitchen faucet.
I didn't want to epoxy cuz that would make it difficult to access the screw to take knob off in event of having to do a valve cartridge repair. But, as luck would have it--even a blind squirrel will find a nut once in a while-I did find the exact knob on Etrailer...
For future reference for those of us with the dual handle faucets, here is the info:
Replacement Knob Handle Set for Phoenix Faucets Catalina Dual Handle Faucets - Clear
Item # PF6-R40-9HC
Item # PF6-R40-9HC
Re: kitchen faucet.
Great that you were able to find the exact part. Interesting that both handles turn in the same direction to turn on. Most faucets that I remember have the hot and cold rotate in the opposite direction.
