Awing
Carolann22
Awing
Post by Carolann22 »
Learning to open awning. The support arms when closed seem to fit behind red tabs. Are the screws holding the red tabs loosened and tightened each time the awning is used
Trying to figure out how to upload a picture.
I have a 2004 Concourse
Re: Awing
No Ned to loosen the screws holding the end tabs of the arms in the red thing. Once you have awning open, loosen the turn screws at outside end of each arm and then slide arm back (toward outside edge). This will bring the other end of the arm out from its holding place. Rotate the arms on the pivot and insert the end into the holder on side of Rig body. Then insert the middle pole of awning (adjust length using turn screw) then raise each side to desired height, again using turn screw on each arm.
Taking awning down is process in reverse.
If not clear, happy to elaborate. Good luck.
Carolann22
Re: Awing
Thanks I’ll give it a try
Carolann22
Re: Awing
Got it. It was so easy after learning the right way. Thanks so much
lcrockett06
Re: Awing
Post by lcrockett06 »
Are there pictures or a pdf on opening the awning? Have searched but not found anything. Have a 2006 Concourse 2100. Awning says horizon 22.
Turning the crank the back opens up but not front. Have pushed on red tab with no results. Appreciate any help
Blewett
Re: Awing
Post by Blewett »
lcrockett06 wrote: December 29th, 2024, 6:37 pm Are there pictures or a pdf on opening the awning? Have searched but not found anything. Have a 2006 Concourse 2100. Awning says horizon 22.
Here is a link to an instruction manual that should help.https://bryantrv.com/docs2/docs/operating/aehorizon.pdf
