Wait, who is "Victron" that is telling you this? I don't believe that is correct, but let's go right from their manuals.deppstein wrote: February 25th, 2025, 7:38 am I'm back with a question about how to get the best temperature sensing for charging from the batteries in the case of my build (Orion XS and IP22). I was planning on using the remote temp sensor attached to the BMV 712's smart shunt for this purpose, but now I have been told by Victron that neither the Orion or the IP22 will be able to automatially adjust temp parameters using that sensor...they simply don't speak to each other.
The idea here is that you will be using a Victron "Smart Network" to connect your BMV with temp/voltage/amp sense, your IP22 shore charger, and your Orion XS. Your BMV 712 will use the optional temp sensor lead to connect straight to the battery post. This powers the shunt AND senses temp. In fact, you cannot use more than one sensor in a Smart Network (according to the manual) so you can't also have a Smart Battery Sense, or even another BMV with another Sensor.
Below are annotated (I added the colored boxes) excerpts from Victron's "Smart Networking" manual. (Rev 5, Feb 2024 -- newest version). Click to enlarge:
1) Basic concept
2) Further details, specifically calling out how lead acid batteries need their charging voltage adjusted for battery temperature. Again, this is directly from the Smart Networking manual :
3) Smart Networking product compatibility chart, showing the BMV temp sense, the IP22 charger, and the Orion XS:
I use this same system (Victron Smart Network) with a BMV 712 and temp sensor (plus IP22, Orion XS, Smart Solar MPPT's) in a house battery system.
If this is wrong, I'd love to know more.
