Advance summary:
You can do it! You have your smarts, the Chinook forum, Chinook diagrams, and then your van guy. But mostly, I know YOU can do it.
deppstein wrote: January 30th, 2025, 11:26 am
Picking up where we left off, I'll attach some pics of the "Spider Web" currently on my House Batteries.
Ahahaha...
more below.
deppstein wrote: January 30th, 2025, 11:26 amI had a talk yesterday with Eddie (the Custom Van Guy doing the install)...he is "on board' with all we have discussed regarding the IP22, Orion XS, dual 4 awg from Start to House, Smart Shunt with temp sensor...
Good!
deppstein wrote: January 30th, 2025, 11:26 amAnd he had a suggestion as to how best to address the wire clutter. He thinks I should run all of these wires through a Lynx Distributor. Neat, clean, and works fine with the rest of the system (Chargers, Smart Shunt IP21). So, I looked at it...makes sense to me. Thoughts?
Personally, I never choose the Lynx, but it can work really well. I do have lots of Victron equipment, so I'm generally on board. I just don't love the Lynx for a couple of reasons: 1) It's quite bulky for what it does. 2) I just never love Mega fuses (which the Lynx uses). They have always been known as kinda cheap, and they only go down to ~100 amps, meaning you still need other fuse blocks etc. for things that need smaller fusing. But even then there is a gap, because ATC type smaller blocks only go up to 30a.
Again, they do the job. And they are blue and have a matching cover. I might choose something else after looking at what you have there (maybe a Blue Sea Safety Hub 150 #7748 -- Just depends). Basically you need something like an MRBF or two right on the battery either way (these have the correct AIC rating where neither Midi nor Mega fuses do). In the end there should be like one positive and one negative wire that actually go to your battery posts (and the BMV temp sensor). Everything else will go to your fuse blocks (positive) and bus bars then shunt (negative).
Where I would start this is at the batteries. You aren't living in the Chinook right now, I presume? So rather than approach this from the angle of adapting all the old stuff slavishly to the new setup, I would pull everything off the batteries, while identifying things as you know what they are and labeling them (hint: Look at the Chinook wiring diagram). As I remember it there was not that much. So you pull everything off the house batteries and then organize/replace them. Ignore the LVD - that's going away so you don't really care. I can give you a start, just based on the original Chinook wiring. Here is the diagram from the 2000 Manual. I'm sure yours is very similar (tho as I type I can't see the year of your Premourse).
We are talking about the positive wires for the most part here:
1) Look at the Purple arrow on the diagram above. This is a red wire, IIRC 6AWG, that comes from the Surepower 1315. You will be discarding this. Buh-bye. (Extra points if you pull it out and toss it.)
2) Now look at the pink arrow on the diagram. This is an 8AWG red wire that comes from the brown box (through the LVD and a crusty, crappy self resetting breaker mounted below, which you will be FORGETTING ABOUT. You'll be tossing this wire out and replacing it with a single wire from the brown box (either by extending the wire that is on the LVD now, or MUCH better, by running a new, 8AWG red wire behind the water tank straight from the brown box to the new fuse that will be protecting it (from there a main wire goes to the battery).
3) Now look at the green arrow on the diagram. This is going to be a smallish wire that comes from the LVD. It also goes through a crappy self-resetting 15a breaker. So, you can tell this apart from the (also small) original solar wire because the solar wire has a 7.5 amp inline fuse on it right near the batteries. This wire can be taken out and discarded. Buh-bye. I'm feeling cleaner and tidier already
4) Now look at the teal arrow on the diagram. If you still have it, this is the incoming wire from the original roof solar panel (via the original solar controller). This has an inline 15a fuse, so that's a clue. There is a corresponding negative wire that comes with it. Feel free to eliminate this and it's solar controller if you like. Or put it back, using a small fuse on your Safety Hub 150 (or a separate small fuse block if you use the Lynx). No need for a bunch of inline fuses floating all over the place.
5) Now look at the orange arrow on the diagram. This would be a 6AWG red wire that comes from your generator starter. That you no longer have.... I can't say how they fuse this on yours because in my era it went up to the start battery. But they used a small breaker that looks like a Blue Sea 285 on mine right near the start battery, so maybe you have one of these near your house battery.
Although I don't love the heavily stranded wire they used for this (certainly don't put it into a Victron terminal), if it's long enough you could re-purpose it as the wire that goes from the house battery to the brown box (since you no longer have a built in generator) if you wanted to.
That's basically it. Anything else is a new added thing and if you like, we can suss it out. Like maybe your new solar. I'll stick with you. I just finished helping a friend with a job where we had to identify like 75 completely inexplicable wires. We got them all figured out. Process of elimination. In this case we have the Chinook diagram, plus knowledge of many Chinooks. Yay. But so how about you find and remove all of the wires listed above? Label them (blue tape or whatever, just for now). Plus your 1/0 inverter wires. Now is there anything left? Show it to us here and we will figure out what it does and if you need it anymore or not.
(You don't need any of these in place to drive the Chinook, as we are not changing the Ford system here.)
I can tell you are smart and capable (hey, you got those Copenhagen things and your headlights figured out, come on!), so I see zero reason that you cannot get it to this point yourself (or with our help) and have it all taken down and labelled when you get to your van guy (since you mentioned not wanting to take too much of his time). I imagine he would be thrilled.
deppstein wrote: January 30th, 2025, 11:26 amBut now those "Spider Webs" have me nervous about cutting things out of the system. I mean, how the hell can I tell whether those little lines (red with yellow in line fuse) from Pos, and small black from Neg are the "long skinny" or solar direct connect that I had installed...and which one of these wires from the pos go to the Blue Sea? The only one I can identify for sure is the 1/0 inverter line!
Again, you're not living in the Chinook right now, right? So just remove the wires from the house batteries as described above. Whatever is left after that, if anything... show us. Forget the LVD - that and its spiderwebs are going in the bin (I hope!). You and your guy (and us if needed) will have no problem at all building it back up. But what if you somehow missed something? Say an invisible, transparent wire
That thing won't work. That's all. We'll figure it out and make an adjustment. This system is a bit messy, but it is very simple compared to a big boat or something with 10,000 systems.
Another thing we have going in our favor is that Chinook made only very slight incremental changes. And their diagrams are good! I bet your system is sooo similar to mine, from 1999. After I removed my LVD the list of things that unexpetedly no longer worked was.... zero. None. The system just doesn't have any hidden weird things. I mean the LVD is weird (and these days, horrible) but.... it's all shown on the wiring diagram. I found nothing that didn't match.
deppstein wrote: January 30th, 2025, 11:26 amSo (going against your "SO CLOSE" urging, and LVD removal begging), I am actually reconsidering leaving the LVD and Blue Sea "as is."
I'm not sure what "the Blue Sea" is? Maybe you could remind me. But the LVD. Look, I can't force you to do anything. Tho, ha ha, I've tried! But leaving the LVD there is just such a bad, unnecessary idea. I'd like to say a stupid idea. Let's just look at one single disadvantage and ignore the rest. Look at those horrible crimps on those wires. Come on, those are laughable. They were bad on Day 1 and now it's day 7,300 and they have bounced down thousands of miles of highway (that does not improve them!) What happens with bad crimps? Heat. Heat starts fires. Fuses and breakers don't do a single thing to mitigate that. Why leave them there to potentially start your lovely Chinook on fire when they are doing
nothing for you any longer? Or, discounting that as an unlikely scare tactic: Why leave them to make troubleshooting any future problem a total nightmare? Why leave those absolutely horrible, automotive "self-resetting" breakers (great, so if there is a problem they just... reconnect .... swell... what could go wrong?).
Really, I can't imagine your van guy - who sounds skilled - would even want to do the job and leave that there. I mean it's like asking a dermatologist to just ignore this one big throbbing lump, but go ahead with my dermabrasion.
Now to be fair, there are hundreds of crappy old crimps all over the Chinook. Those were the times. But at least those are all on smaller wires, that carry smaller loads. Not on big parts of the DC distribution system
that you don't even need anymore.
Okay, got that out of my system. Whew.
deppstein wrote: January 30th, 2025, 11:26 amI understand that there would be issues of interference between the Blue Sea and Orion XS IF Blue Sea was operating.
I'm sorry but I have completely forgotten what you are referring to as "The Blue Sea."
deppstein wrote: January 30th, 2025, 11:26 am BUT, if I were to use the manual shut off and keep it off, those things would all go away. And I could effectively combine a few things--like Solar and Blue Sea loads, and Orion XS and IP22 loads on a single lug on the Positive bus of the Lynx Distributor (Orion and IP22 won't ever run at same time) to have everything fit onto the Lynx.
I don't love that idea of "doubling up" on the Lynx, plus the Lynx fuses can't fuse down to 60a. I would design the system to have enough fuses of the proper sizes. In the same way, you can't put smaller wires on the Lynx. Same reason, fuses are too large to protect the wire. You would need to add something like a Blue Sea 5025 or 5046 to handle the smaller wires. There is still a gap though between around 100a and 30a with this approach. Or use something like the Blue Sea Safety Hub 150 (part #7748) which handles three jobs (the Lynx, a negative bus, and fusing for smaller wires). The 7748 can take Midi fuses from ~250a down to 30a, and ATC blade fuses from 30a to 1a. So it can do large distribution and small distribution both. While I wouldn't always choose the Safety Hub 150, I did use one when re-doing the Chinook, because it fit the scenario well, and is very compact. No need for extra pigtails (that you need to fuse) going to separate small fuse blocks. But the main thing is that there are lots of "right" ways to do it. As long as it's tidy, everything has OCP (over-current protection), and any wires coming right off the battery have fuses that meet the AIC rating. None of these ways call for the LVD though (
So for two examples of "paths" for your DC distribution:
1) House bank ---> MRBF fuseholder/fuse ---> Main battery switch ---> Lynx ---> Blue Sea 5025 or 5046 fuse block. Plus Shunt ---> negative bus bar.
2) House bank ---> MRBF fuseholder/fuse ---> Main battery switch --- Safety Hub 150 (BS 7748). Plus shunt.
You would use MRBF main fuse/holder on the battery in any case because it has the proper AIC rating to handle a battery bank short (Lynx Mega fuses and Safety Hub's Midi fuses do not, so same same between the two). This would be a Blue Sea 5191 or 2151 (all of these Blue Sea part numbers can be searched on their website to see more about them).
deppstein wrote: January 30th, 2025, 11:26 amTo do the full Blue Sea and LVD elimination, I need more encouragement and specific advice as to how to go about it without screwing it up.
I hope I have given you that here? But if not, come on back at me.
