Marksman keyless entry
- Attachments
- MarksmanM2-KeylessEntry1.pdf
- (43.63 KiB) Downloaded 634 times
retiredtim
Re: Marksman keyless entry
Concourse,
Did you install keyless entry yourself? If so can you tap into wires in the door handle?
retiredtim
retiredtim
retiredtim
Has anyone out there tried to install a keyless entry system?
Factory option, I did not install it. I don't own the coach anymore or I would map out the wiring connections for you.
Here's a photo of the Marksman unit mounted and the thin red/blue/black wiring. Looks like some wiring goes to the door (original masking tape).
retiredtim
Thanks for the post, not sure what I'm looking at. Bought a cheap system on ebay and tried to tap the wires from the drivers door but didn't work. Have you retired from RVing?
I have a request - just meant in the nicest way, not as a mean criticism. Since this is the reference forum (for posting manuals, codes, and etc), would it be okay to take discussions and how-to questions to a new thread in the main forum? A new thread could be started there, with a title something like "Marksman or other keyless entry questions" and then take it from there (with a link from here if you want to get fancy).
Again, I don't mean to stifle anything, but just to try to keep the reference forum for documents and reference data, so that folks coming here for such don't need to sift through other discussion. I hope it comes across as I mean it because "other discussion" is what we're here for! But just... in the other areas of the forum.
Agreed. I would create a new thread in a different area if I had questions but new users won't likely know to do that. Other forums choose to lock threads like these reference material threads OR forum moderators will move discussions to the appropriate areas.
- red_land_baron
I posted a blurb, diagram and description about my keyless entry system (in the wrong place) in Trip Talk - "What are the chances" in response to mods I have made to my 2000 diesel Concourse. If need be, I can re-post here.
RLB.
RLB.
2000 7.3l diesel Concourse
