Lounge folding table 1998 Premier question
Roly
Post by Roly »
Greetings. I pose a question for anyone who has messed with the folding table assembly. The type that lifts up then slides into a casing. I wonder how it is secured to the cabin side. I leaned on it too hard and broke the top off, and now need to rebuild and reinforce it.
Any suggestions? I'm sure other such have broken as the construction is light.
Thanks, Roly
1998 Premier
Re: Lounge folding table 1998 Premier question
Hey Roly,
My ’94 had a faux oak luan panel pin-nailed to the main carcass, and the carcass was screwed to the wall. I gently pried the panel off, and the rest was easy.
When the table was in the out position, I used a short curtain rod under it so the floor would support the load. The original cantilevered design was flimsy. :roll:
HTH
caconcourse
Post by caconcourse »
Roly wrote:Greetings. I pose a question for anyone who has messed with the folding table assembly. The type that lifts up then slides into a casing. I wonder how it is secured to the cabin side. I leaned on it too hard and broke the top off, and now need to rebuild and reinforce it.
Thanks, Roly
There are square-hole screws holding in the whole table assembly. As I recall, there are two on the top flange, and two in the floor on the bottom of the wine cabinet. It's not hard to get out if you find all of the screws.
Roly
Post by Roly »
Thank you HTH and Clay. I'll check it out and maybe improve the table some. Thanks the the help.
Roly
1998 Premier
