Info on duell privacy shades
dougm
Re: Info on duell privacy shades
Post by dougm »
ok, i will have a look, or just call them and ask if they have any brochures with optional blinds.
RetiredLife2023
Post by RetiredLife2023 »
We recently purchased a 2002 Chinook Concourse and experienced the window shades on the driver side (above the sofa-bed) will not stay up anymore. They were working fine, but last week-end when I raised them, they slowly slid down. Is there a trick, or do they need to be replaced? Or, I see that they can be re-strung....not too sure if we have the patience to do that! Just curious...
caconcourse
Post by caconcourse »
If the blinds are not staying in place, it usually means that you need more tension on the strings. There should be a bobbin on the wall where the strings mount, and you can take a wrap or two around the bobbin to increase tension until the blinds stays in place.
For those that don't want to restring themselves, I used Pat Miller in past and she did great job. 503-390-8681 "RV Shade Repair".
