Summit Transfer Switch Location?
TheIceKing
Post by TheIceKing »
Hi All,
I am a new (used 2004) Summit owner and are trying to figure out few issues with the electrical system. Can someone with a Summit share where the transfer switch is located? I do not see in under the galley countertop where the inverter/converter is located? Thanks.
Re: Summit Transfer Switch Location?
No idea, so I am just shooting in the dark here... for my Concourse, it is right behind the AC panel box (brown box). You can try to look at the AC panel, and trace the wiring from the breaker to the genset or the shore power, and there should be a transfer switch there. I hope this will give you something to get started.
