New to the forum and looking for a chinook
Re: New to the forum and looking for a chinook
Is these another location that the tank could be relocated to. I am sold on having the permanent Bed in the back and want 4x4. is there room under one of the dinette benches?
markatherton
There is storeage under the permanent bed but would require a custom water tank to fit the space and you will lose a significant amount of storeage.
markatherton
The water tank is already inside of one of the dinette benches but it extends under the rv so it has a decent amount of capacity. The water capacity is less on the side entry. "Where there is a will there is a way"
I tried to lookup side entry black and grey tank location, but the info is not readily available. You may want to make sure these two exterior tanks will not be in the way of the 4X4 up grade. The fresh water tank is going to be pressurized after the pump, so it can be located anywhere, if you don't mind about where to fill it. The black and gray (or it is grey????) tanks are less flexible.
dells2000con
Saw this one last month at the Portland, OR RV show. Then I was driving by Puyllaup RV's Vancouver, WA lot about a week later and saw it sitting there. I've seen so many RV's lately I can't recall it's condition that well, but that may be good, if it looked in bad I'd probably remember it.
https://puyalluprv.com/inventory/2005-c ... lacier-25/
2000 Concourse "Hummingbird edition" Triton V10 Banks Power kit
