Super Sophisticated Window Latches
Kirah
Post by Kirah »
My windows tend to rattle open when going down the road, so I devised some fancy window latches to hold them shut. :lol: Against all odds, they worked great. A day's drive in each direction, not a whistle out of the windows.
I cut them a little long, so they wedge in tight. The dowel bows a little bit; I bought one that was smallish because I wanted it to fit inside the track.
Re: Super Sophisticated Window Latches
Those are sophisticated. We might need a diagram :lol:
My drinking straw screen clips really belong here too :mrgreen:
(Originals are Unobtanium but the straws are still going strong a couple years later.)
PS: Ha, just noticed your signature line. "Why yes, Kirah has the minus-dinette layout."
pdemarest
Post by pdemarest »
Kirah, I think you may have infringed on Blue-Go's patented "Door Stick". Blue, you should sue for royalties!
dougm
Post by dougm »
what do the original clips look like? Any have a complete one they can send me, i mean like a broken one with all the pieces so i can see what it is and maybe work on reproducing them?
Kirah
Post by Kirah »
dougm wrote: November 20th, 2018, 12:49 pm what do the original clips look like? Any have a complete one they can send me, i mean like a broken one with all the pieces so i can see what it is and maybe work on reproducing them?
For window latches, there's a few styles floating around, but this is what's on my windows
https://smile.amazon.com/gp/product/B00 ... UTF8&psc=1
Blue is talking about some screen clips. I don't have any clips, as far as I can tell, my screen just sits in a track in the window. I haven't seen the clips.
Which were you interested in?
Doug,
I have always wondered if someone with a 3D printer (and the knowledge) could reproduce these specific screen clips. I do have one set (there is a top and a bottom clip), and I have photos.
(These are clips that are specific to a certain Hehr window that was used around 1998-99 (maybe earlier) that was then discontinued. The screen clips are discontinued and impossible to find!)
I'll start a new thread for this, Doug (or maybe piggyback onto one from before that is about these clips).
PS: The Door Stick™ is open source :mrgreen:
dougm
Post by dougm »
both i suppose, i have access to a 3d printer, but i would need complete clips even if they are broke in two so that i can get measurements
Will the 3D printed latches be strong enough to be practically used? I assume you do not have a metal printer.
dougm
Post by dougm »
Depends on what media you print with, if you use the correct media its quite strong. Much like the ABS plastic sewer pipes and fittings on your Chinook, ABS plastic is considerably stronger than PVC, but the PVC is more flexible.
Just to be clear, the pieces I was referring to are tiny little plastic clips that hold the screen in place - and allow it to slide - on the circa 1999 Hehr windows. They don't need to be very strong (which is why drinking straws are doing the job, albeit not as nicely as the originals.
