I am currently looking at a 2004 Glacier in very good condition and low mileage. Any particular areas of concern with this model?
Thanks!
2004 Chinook Glacier 2500
Jermanitor
Re: 2004 Chinook Glacier 2500
I bought one two years ago. No problems yet. Mine had 40K when I bought it. These engines are pretty dependable.
Only thing I've ever heard is making sure the slide works smoothly and the slide seal bladder works.
Thanks for the feedback. Slide works great, and bladder is good. Going to take another look tomorrow and check out all the "systems". She has 47K on her, and it is currently a toss up between an '05 Concourse with 10K more miles, and same price. I really like the extra room (and bathroom) in the Glacier.
If you have no problem drive the larger vehicle, you can't get too big. I would go with a Glacier too.
Carol and Wayne
We bought our Glacier last spring and left it in Arizona as we had trouble with Canadian Transport saying it did not make Canadian Safety standards according to VIN Number. I did a carfax and it spent 6 years in BC Canada. So instead of fixing the info on the VIN number, they sent me a 6-month letter allowing it to be imported into Canada. We had already left Arizona and now the letter has expired. The VIN says it is a Ford Econo van and not a Chinook Mortorhome. That was a comment more than a question. My question is the slide. When we came back to our winter place in Arizona, we had issues that "We" did not understand. Paying RV repairmen that did not understand our Chinook any better than us... Last straw was yesterday when we were leaving Palm Springs from a 2-night stay and the slide would not go in. i believe it was our lack of understanding the process of bringing it in and the lack of knowledge of the "2" repairmen that came out. $300.00 later after their service head-scratching call, under the motorhome banging, they said the compressor was screwed and they released the air out of the bags. Had all the computer boxes out and decided to push in the slide manually, hence the rain we had run off the slide and into the computer box. I said "Wow, that is not good," The main repairman said, its ok, there wasn't much and the other man said, it will dry out while you are driving..... I am not even sure what my question is, to be honest with except, I don't think we will put the slide out again..... Hopefully, the computers will work to put the bed down..... Any comment on this situation???????????? Appreciate any help! Will try a local dealer of RV's mechanic, but is there anything that I can tell them in regards to the series of actions to get the slide out to begin with???????Jermanitor wrote: December 8th, 2017, 4:44 pm I bought one two years ago. No problems yet. Mine had 40K when I bought it. These engines are pretty dependable.
Just bought a Glacier and having slide issues. What did you do about your slide problem?
djmoynahan
We just bought a 2004 Chinook Glacier & have slide issues, found the bladder was always deflated. Went all the way to HWH, spent 2 days there, left there, drove 8 hrs. - slide wont go back in. We cannot use our slide, any suggestions.
To retract the slide. Press emergency brake. Turn key to activate slide. Yellow light should start blinking. Slide bladder should start to deflate. Air compressor may start to run. Yellow light should stop blinking and stay on. Press retract button. Hydraulic pump should start to run. A few seconds later slide should come in.
At what part of this sequence is not happening? Yellow light is not blinking? Slide bladder does not deflate? Yellow light will not stop blinking and go steady? Hydraulic pump does not run?
