low voltage
retiredtim
low voltage
Any idea what would cause the battery to kick on low voltage with nothing connected to battery even disconnecting convertor?
retiredtim
Re: low voltage
house battery reading 12.4 same as car battery. the low voltage on wire going in reads 13.0 same as going out but within 30 secs or so out reads 10.5 then disconnects the battery.
retiredtim
Re: low voltage
It looks like the LVD is bad. If I by pass it every thing works. However, I don't really run without it. Does anyone know where I can get a replacement for a 50amp LVD???
Re: low voltage
if mine goes i will put in a blue seas lvd, only thing it does not have is a light the senses charging source. but for me that is not important
retiredtim
Re: low voltage
thank you. I've ordered a blue sea 7635. will post if that works.
retiredtim
Re: low voltage
The blue sea works, only issue the switch doesn't have a shut off for storage.
Re: low voltage
i you press off you will disconnect till it see's a voltage chargeretiredtim wrote: May 30th, 2024, 10:46 am The blue sea works, only issue the switch doesn't have a shut off for storage.
