Hi all,
The bladder on my 2003 Glacier’s slide out is busted so the air compressor never shuts off.
I have removed the fuse to stop the compressor.
I cannot get to HWH until fall or winter.
I would like to install a shut off valve on the air hose going to the bladder so I can continue to use the air shocks.
A few questions:
1. Does air pressure keep the slide’s security bolts in place to lock the slide and keep it from manually extending as I drive?
2. Does anyone know which hose goes to the air bladder so I can install a shut off valve?
Thank you!
