Ford E350, V10, gas, 103 k miles, runs smooth, ready to roll! Very good condition in and out with some minor cosmetic scratches. Well maintained, A/C with heat strip, Onan 4k generator maintained and exercised routinely. All records available. Front end alignment and new bushings (2020), 6 new Michelin Agilis Crossclimate tires (10/21), new metal valve stems, engine coils, boots and plugs replaced, engine battery (2/23), house batteries (7/22), cabin pressure tested, no leaks, caulk refreshed, added dedicated antifreeze uptake to water pump, upgrade 30amp cord to Safeplug(R), new dump valves (10/23) and sewer hose stow tube (4/20), safety detectors replaced 2020 ( carbon monoxide, smoke and propane) and much more. Rear entry, dinette model. Removed the sofa bed for a twin mattress, but available if want to reinstall. Extra storage on roof in Thule clamshell and the extended tow bar included (prior owner towed boat). In Boise, Idaho, ask $45k, reason, sadly a life change.
Photos will be posted on RVtrader.
2004 Chinook Premier for Sale
Forum rules
Vendors are strictly limited on the website. If you make, import, wholesale or otherwise provide any product or service for compensation, or receive any fees, bonuses, product or commission for products, providing links, customers, information, or reviews, you must contact the forum owner for a vendor tag before actively pursing any business, review, or related activity on the site. Hobbyist manufacturers are encouraged to provide unique goods or services, but also must obtain an appropriate vendor tag.
Vendor tags are simply an identifier, are provided free of charge and must be for a product(s) or service(s) which benefit the forum members.
You may however, conduct yourself freely as a member of the site with no tag, provided you do not advertise or otherwise sell, link to, provide a website for, or engage in any other activity that could be construed as vendor related.
Re: 2004 Chinook Premier for Sale
How is the Thule clamshell attached to the roof? Best of luck with the sale.
On raised feet, anchored to roof and sealed. There is airflow under it, and enough room to clean fall leaf debris.
Thanks for comment!
Thanks for comment!
Apology Mr Blewett, clamshell is attached to rails which are affixed to roof. I reviewed my photos and have one which demonstrates the rail, similar to a Yakima or Thule roof rail system. Working on the rvtrader listing today.
