2001 Chinook Concourse Fuel Pump Replacements
Posted: June 28th, 2023, 11:32 am
Hello all - and thanks for any input here!
We have 2001 Chinook Concourse, E350 V10 Triton, just passed 90,000 miles (purchased at 78,000). We are the third owners as best we know.
A year ago we addressed the catalytic converter - we were choking and losing power up grades of any sort. A new cat solved that problem. We also dealt with a fuel leak from the fuel fill hose. That fix included dropping the fuel tank, and since it was down, we replaced the fuel pump and fuel lines as well.
This year we decided to do the spark plugs (having no idea if they had ever been replaced). That job got done by a new mechanic.
HERE IS THE ISSUE: New mechanic believes the wrong fuel pump was put into this vehicle when we dropped the fuel tank. The mechanic is stating that the fuel pressure is at 90psi, way too high and thus flooding the engine and running rich (I believe we want to be 30psi or there abouts?). This problem is causing misfires as well as fuel efficiency, and down the road will burn out the catalytic converter. Mechanic believes the pump that is in there is electronically controlled, but our vehicle wants a "mechanically" operated fuel pump. Does this make sense? Suggestion is to drop the tank and swap out the fuel pump for a "mechanically" operated fuel pump. (Apologies for the non=professional notes about the different pumps, I am a bit unclear on the issues).
Does this info make sense to any owners of a 2001 E350 chassis?
Thanks in advance
Ben in Colorado
Thanks in advance
Ben in Colorado
