New Member 1998 Concourse
Fawn
Post by Fawn »
I'm a happy new owner. I can't stop going in and out of the rig and marveling at its bells and whistles. I camped once and everything seems to work well. It's immaculate. The seller was wonderful.
Here's the question: It does need front brakes (pads and rotor). I live in Marin County, CA and the mechanic says the job will be about $900. I have no idea if cars are that different than motor homes but it seems like a lot. Does anyone have any idea if this is way off base? The mechanic is new to me and they seem to have good reviews so I'm trying him out. BTW - I'm reading comments from the recent post of another new member. Thanks for the replies to their post. It's helping me as well.
Re: New Member 1998 Concourse
the brakes are standard E350 stuff (though some of us have upgraded to E450 stuff). There is often an upcharge since they can't just put it on a standard lift for cars. Sometimes an upcharge for rusty parts being a pain. I think you should get another estimate.. I think for $900 ypu could probably get E450 parts (though you might then need larger rims/tires also to clear the bigger brakes).
I have a 2004 Premier and live on the East Coast—if I could get front brakes done for $ 900, Id jump at the chance. Going with the 2008 larger brake set is well worth it—much better stopping power. And I did not have to change tires or rims.
Enjoy your new Ride!
Fawn
Post by Fawn »
Thanks so much. I'm relieved to not have to go shopping for another mechanic. I'll call today and see what the upgrade would be.
You should still get a different estimate. Once you got to trust your mechanics, then you will not have to do this all the time, but it is always good to shop around to get competitive quotes.
