SAE conductors in our 2000 Chinook Concourse?
Posted: February 27th, 2021, 1:38 pm
I am going to upgrade to a lithium battery system in our RV (More on that later in the project thread – going to install the lithium batteries underneath the couch – It’s going to be fun!).
I have been checking the current battery cable system in the RV and have found to my dismay that the cables from the Onan generator and the Ford starter battery via the isolator (A previous owner had replaced the “Smart” Solenoid with what appears to be a Continuous Duty Solenoid) to the coach battery bank are these: 2 GA SAE J1127 Type SGX cables and not AWG cables. Humm. Has anyone else seen this setup on their Chinooks? Further, there are no fuses on these cables in the connections to the respective batteries. There is supposed to be an 80-amp fuse on the Onan connection, at least I cannot find it, and I am under the impression that there was never a fuse to the smart solenoid for some unexplained reason.
I cannot tell from the lettering what type of 8-gauge wire there is for the converter/charger, but that is not a concern because when I install the lithium batteries inside under the couch, I am going run a new wire from the batteries to the brown box along the couch frame and not use the existing 8-gauge wire that runs up the pillar back to the rear of the RV to the brown box via voltage drop land!
I do not want to have to replace the current 2-gauge SAE cables with AWG wires, but I don’t know what fuses should be there. According to Blue Sea Systems: “SAE conductors are smaller than AWG by 5% to 12% with current capacity typically less by 7%. So, a #2 AWG with a temperature rating of 105 degrees C insulation in the engine compartment requires 179-amp fuse or lower, if I read the Blue Sea Systems Ampacity chart correctly. Then, with the SAE wire would the corresponding fuse requirement be 7% less, or roughly 166 amps, or lower? That would be my guess…
