Fresh water tank
Posted: February 23rd, 2021, 2:31 pm
by Zayvier
Hi. I just purchased a 1976 dodge chinook 18 plus 2. It has a fresh water tank that has this Info in it:
Inca T 1237
AIPMO
T
I can’t tell the tank size. This tank looks original. Is it on to use it if it works fine/no leaks? Are there any concerns for using such an old tank for drinking water? Can I sanitize it before filling it?
The previous owner added a filtration system just before the kitchen faucet pipe- so this should help.
Has anyone heard of this brand tank?
I will add pics.
Thank you,
Charlie
Re: Fresh water tank
Posted: February 23rd, 2021, 8:26 pm
Sanitize it, it should be fine. Check for leak by filling it up all the way to the gooseneck, and see if the level drops. If it drops, then there is a leak or the water goes somewhere. Read the manual for instruction for sanitize and draining the tank.
I would replace the inline filter before the kitchen faucet.
Posted: February 23rd, 2021, 9:11 pm
by Zayvier
Thank you for your reply. I’ll sanitize it this weekend and check for leaks as well as replace the filter.
Posted: February 24th, 2021, 4:39 am
by BobW9
Zayvier wrote: February 23rd, 2021, 2:31 pm
Inca T 1237
AIPMO
T
Inca Plastics Molding Co. Inc.
http://www.incaplastics.com
I didn't see that model in their PDF catalog, so you would need to contact them. That is so old, they may no longer have the mold, but might have the dimensions somewhere.
Posted: February 24th, 2021, 8:08 am
by Zayvier
Thank you. I emailed them yesterday and they said they discontinued that mold and that it is ok to use a tank made back the. That there is no danger from the plastic used.
Posted: February 24th, 2021, 9:42 am
If there is no physical damage to the tank, any chemical that could leech out into the water probably already leeched out by now. My rule of thumb is that as long as the container is newer than when the content was made, it is good
