Hitch receiver height
Posted: October 13th, 2019, 12:08 pm
by Yupong
I have a 1998 concourse with the manual step in the back. Does anyone happen to know the hitch receiver height? I am planning on flat towing a smart car and the connections on the car are 14-1/2 inches off the ground.
Re: Hitch receiver height
Posted: October 15th, 2019, 4:43 am
by Kirah
Sorry, I don't know that without getting over to the camper to measure. I'll be down to do some work this weekend, and I could measure then, if you still need it.
FWIW, I put a bit of a riser on to tow my Honda CR-V. Smart Car looks like it sits lower, so you may be okay with a straight hitch.
Posted: October 15th, 2019, 9:33 am
The center of my receiver measures 19.5 inches from the ground with the rig fully loaded.
I think the rear of my rig is bit higher than most Chinooks, but I could't say how much.
Hope that helps.
Posted: October 15th, 2019, 10:30 am
I set my MorRyde spring to be at the highest setting. I can go home and measure it tonight, but depends on the suspension setting, it can be adjusted by maybe 3 inch down if I want to. Isn't the receiver height can be adjusted with adapter to account for the different height anyway?
Posted: October 20th, 2019, 8:28 pm
The bottom of the hitch is 14.5 inch from the ground. The bottom of the outer square tub is badly scratched, so I think it must have hit bottom on many, many occasions.
Posted: February 24th, 2020, 3:24 am
by nikkireed
I think the rear of my rig is a bit higher than most Chinooks, but I couldn't say how much.
I hope that helps.
