Furnace removal from Concourse
Posted: August 1st, 2014, 11:22 am
I wasn't sure whether to put this in the appliance section or the project/mod section - chose the project/mod section since that's how I think of it in my rig.
Anyway, I decided to remove the stock propane furnace from my rig. My reasons were as follows:
1) I virtually never use it. Not that I don't use heat - I do! But I don't like noisy, "blowy" heat. Not only do I not like the sound (wakes me up) but I feel toasty/hot when the furnace is running, and then cold when it shuts off (not specifically this furnace, but all similar furnaces). The stock furnace also uses a fair bit of battery power for the fan.
2) When I have hookups, I use a small electric heater.
3) When I'm boondocking I don't want the battery draw (or the noise, etc.)
4) I plan to use a Wave 3 catalytic heater when boondocking (with all proper ventilation precautions). No battery power, silent, radiant heat (my preference).
5) The furnace was relatively easy to remove and store away safely (off the rig), and it will be easy to reinstall should I or a future owner ever want to.
6) Given that I didn't really use it, it was occupying prime "bulk" space for storage (vs tiny cupboards), in a place where extra weight is not bad (ahead of the rear axle, at floor level). Hated to see that going to waste!
7) Side benefit is that I can easily use the 12 volt power wire to make a "charging station" for my 12-volt items (phone, computer, etc.), and it will be right at the table where it's handy.
Okay, so with that preamble, here we go. Before I started, I shut off the propane outside the rig, and then lit the stove until the flame went out on its own (remember to turn the stove burner off after this). Then I removed the fuse in the fuse box that goes to the furnace wiring. Of course this should only be done if you feel comfortable with the process, and I can't say for sure your rig is the same, what your skill set is, what risk there might be, etc. etc.
My rig is the "Club Lounge" layout, and the furnace is under the forward club chair, in an upholstered "box." You may have noticed that these chairs are a bit higher off the floor than standard chairs would be. I think that's because the furnace dictated the height. But it looks like they tried to get it as low as possible, and so the furnace is in a recessed bit of floor, and hence cannot be pulled out through the door to the seat box. Instead the seat box needs to be removed first, then the furnace removed, then the seat box put back. I can tell you that whomever had to install the seat box (after the furnace was in) must have drawn the short straw that day at Trail Wagons. Those screws are a bear to reach!
I imagine the dinette layout would be somewhat similar, albeit there may be more working room.
There seems to be a three-photos-per-post limit, so I will continue in subsequent posts.
First of all, I opened the "door" to the forward seat base. You know how the door to the rear seat base pulls open with a handle? Well the forward "door" is in the same place but just held in by clips. It can be gently pried open with a flat bladed screwdriver or etc. Then it can be tilted down and forward, but is still held in by one of the duct hoses (of which there are two). So the first step is to unscrew the duct hose from the sides of the brown plastic vent. I have already removed the hose in this photo, but this shows the screw that held it on (I just put it back without the hose on it).
Next I removed the screws holding the other end of the vent hose (to the furnace). There is a similar vent in the rear side of the box; I removed that similarly.
