Re: Solar and other power options?
Posted: December 25th, 2021, 8:52 am
Note that for heavy vehicles like our RV's, a general rule of thumb is replace all tires every 6 years, even if they look new.
The rubber in tires does age and you can get a flat while driving even if they look new (they heat up as you drive and pressure gets higher, and the old rubber fails). If a tire goes flat or comes apart while driving not only can you have an accident if you lose control, but it can damage your wheel well. The previous owner of my Concourse had that happen in the right rear, and it chewed up the fiberglass around the edges (neither he nor I ever fixed it, too expensive for it to be worth it, at least to me who doesn't care about looks much).
Check the date of manufacture on each tire (including the inside rears) and if they are near or over 6 years, you should seriously consider buying 6 new tires (always change all at the same time). Also note when you buy new tires you should check the dates, because if they are not a brand that is selling well (or on sale, which often means they aren't selling well), they could already be a year or more older when you purchase them - and the 6 years limit starts when they are made, not when you buy!
If one tire is losing air, I'd say check for leaks in the valves. If the tires are at about the same pressure, then it seems to me something else is happening (what are the chances they all have the same slow leak in their valves?).
