Re: alternator
Posted: March 27th, 2021, 5:03 am
You really shouldn't have a single alternator charging both engine lead acid and coach lithium batteries, as they want different charging voltages. A standard alternator will have a charge profile for lead acid, of course. The options to do it properly that I've heard of are:
a) Use a Battery-to-Battery (B2B) charger like Blue suggests (I have the Sterling Power 60A B2B myself, meaning it uses a max of 60A off the alternator, which translates to maybe 50-55A to the lithium batteries because of losses due to the device doing its thing),
b) Install a second alternator in the engine compartment that is only for the coach, and has a lithium charging profile or is programmable,
c) I think I've heard of having an alternator with a separate smart charger module that is programmable, though I'm not sure if that allows for just programming the profile or if 2 different outputs can be set (one for lead acid, the other for lithium). Or maybe one alternator with two different charging modules attached to it?
