There is one holding tank, and it is under the sofa. you can also check the level on the monitor above the stove. If it is not full, the water should able to pour into it via gravity. It uses a spa water hose. You can check to make sure there is no obstruction in the path with a clean 1/4 inch tubing, for example. You have to practically park your rig at 45 degree side way to have any effect on the gravity flow.
As for the photo, you can upload file directly as attachment. There is no external account needed to host the photo separate. There maybe some file size limit, however.
Chinook 4x4 7.3 Diesel
Re: Chinook 4x4 7.3 Diesel
eporter123
The world of forums and photos has changed a bit. Unfortunately Photobucket recently went to payment based and has held a lot of photos ransom. There are ways around it, but now tons of forums have no more photos.Tomsprops wrote: September 24th, 2018, 10:55 amIt’s been a long time since I had posted photos on a forum. I don’t think that I even have a photo bucket account any longer ? It’s a Beauty!
You can directly upload an attachment to this forum. It's hiding down below in the "three bar" tab next to options. Click on that and you can attach a pic from your computer or phone.
Or you might have a tab that says "attachments" - that's how it looks for me. Same function tho. Here is a screen shot of the bottom of the "reply" box plus the attachment tab (as you can see, the "options" tab is in front but once you click on the "attachment" tab that one will display). From there I click on "Add files" and then you basically use that to look through your own computer for photos you want to attach. Once they load up in that tab, you can choose "Place inline," which will integrate them into the text of your reply wherever you had the cursor.
You can click on the photo once or twice to make it larger.
When you think you are done hit "Preview." If things look good in preview (photos show up correctly, etc.) then you can hit "Submit." If things *don't* look good in preview you can then figure out what's wrong and preview again till it's right. Usually for me if things don't show up right I just muffed up a simple tag or something. Again, once Preview shows up right, you can hit Submit and then we get to see your glorious Chinook (or your gnarly problem, or your trip photos, or etc.).
markatherton
Where are you located in California? I am in San Diego....
Well that didn’t work , I’ll keep trying as I’m on a iPhone while I’m still driving it back fro CO.
2001 Chinook Concourse 4x4 7.3 PSD
Aw darn. But there's time to work on that later (I've never posted photos from a phone.)
The Retrieval Road Trip - a time-honored Chinook tradition!
Good traveling to you,
Thanks ! I’ve certainly have tried to make it a Adventure out of it ! This thing is Pretty Badazz ! I’ll have all the systems up and running as soon as I can get to my tools. Well at least that’s what I’m hoping forBlue~Go wrote: September 25th, 2018, 1:24 pm Aw darn. But there's time to work on that later (I've never posted photos from a phone.)
The Retrieval Road Trip - a time-honored Chinook tradition!![]()
ok I seem to be able to post photos from my iPad. Thanks for the Help. I'm home now after making my 1269 mile Test Drive successfully.
