Sure Power Battery Separator clicking sound
Re: Sure Power Battery Separator clicking sound
Blue~Go wrote: August 16th, 2018, 4:52 pm One thing you might check before spending a bunch of time figuring out what is going on, is whether yours is recalled. Mine was (Surepower 1315 installed in 1999). Slight matter of they catch on fire or something along those lines.
I had look at the recall notice like 2 or 3 times, and figured that mine is not on the list. The serial numbers in the recall goes from 11* to 90*. Mine is 99*, so it is newer and above the the range for recall.
Wait a minute! some of you probably say, that the range is actually from 90* to 110*, and 90<99<110, so mine actually is recalled!
I am such an idiot.
So my question now is, do I contact Surepower as per the recall notice, or I need to contact Eaton (I think they got brought by Eaton, not sure), or it is so old that I am on my own?
I contacted them when mine was definitely on the recall list. I didn't choose to "redeem" the recall. As I remember it I needed to go through some slight ordeal to prove things, and.... I really didn't have much interest in a new Surepower 1315 because I don't like the design (newer design magnetic latching units being my preference).
If it were me I'd go to a Blue Sea 7622. Magnetic latching, manual and remote lockout, no built in voltage drop, etc. (you still need an adequate sized cable though).
(I did actually buy one but then decided a manual switch would actually suit me better; however most people would probably prefer the "automaticness" of this type of unit.)
The Surepower is bi-directional, which you may not want, but then so is the Surepower 1315 if that's what they will be sending you instead.
Either way I'd strongly consider moving it off the fenderwell. Hot, can get wet, and hard to access.
Blue, do you know how much current does the magnetic relay version draws? The specs says <40 mA, which is not very precise (but pretty low compare to most things.) The reason I asked is because some design with regular relay uses 12 mA when open, <200 mA when closed. If vast majority of the time it is closed, and if the magnetic relay is using close to 40 mA, it maybe not that bad to get the older relay type (the non-magnetic type is much cheaper.)
Sounds like you have the manual switch... in that case, I will call Eaton and see if they can give me better specs. I may go with the manual route, since I already have a manual battery disconnect.
BobW9
Post by BobW9 »
Blue,
I'm in the process of switching to Lithium coach batteries. What is your take on the bi-directional then? Seems to me I might not want that, since the Lithium will sit on 12.8v a lot of the time (much, much, flatter voltage drop on usage and dod), while the starter battery is regular lead acid.
Though maybe it doesn't matter, as I've already thought that because you really don't want to top-off Lithium, I will probably have to decide each time I drive a distance whether I want to charge the coach or not. What I've been reading suggests the best thing for the Lithium might be to often stop charging at something like 90-95%, and then only sometimes go to 100% (and then stop anything, no float). Or at least not charge when I've only gone done to 80-90% or something at an overnight stop.
Thoughts?
Bob
Bob:
I suggest you disconnect the Li from the lead battery permanently. The charger for the Li have a different charging characteristics, and you do not want both Li and Pb connect together, and be charged by a shared charger any time.
BobW9
Post by BobW9 »
I should have mentioned, I have the Sterling 60 amp Battery-to-Battery charger. This allows me to set the charge voltage, etc, for the Lithium, and the B2B will adjust itself so it pulls as many amps from the alternator (up to 60) as it thinks the Lithium needs, at the voltage I've set (probably going to go with 14.1 or 14.2 volts for the Lithium in bulk, and then have it cut off for no absorption or float). The starter will be at the normal amount it needs.
BobW9
Post by BobW9 »
And I just realized that I can't use a bidirectional separator, because the B2B is only one way and will be sitting in the middle. I currently have the old SurePower 1314 unidirectional, and I guess I'll be keeping it. Hmm, should have thought this out better before first posting, eh? But it is good to bounce ideas off other people, sometimes, so thanks anyone who bothered to read these :)
BobW9 wrote: August 21st, 2018, 9:59 amBut it is good to bounce ideas off other people, sometimes, so thanks anyone who bothered to read these :)
Hey Bob,
You had my full attention when you wrote "lithium" so I can't wait to read more about your project. I'm probably not the only one around here who would love to hear more. Maybe start your own thread, if you care to. Thanks.
BobW9
Post by BobW9 »
Hi, Scott. I'll do that, probably starting in a couple or three weeks. I have the parts now, still need to figure how to mount things, and most important - am going to the beach for a week starting this weekend! So work on the RV waits until I get back (I have been threatened with bodily harm by my girlfriend if I start taking things apart and we don't have power during our vacation).
Just a warning that this isn't about separators clicking. OTOH, it's a kind of natural thread morph...
Hi Bob (and all others too of course),
I helped a friend put in a lithium system over the winter and even though he bought a premium brand (Victron), I was a bit frustrated about the charging guidance (I'm spoiled by the Lifeline Battery Manual which tells you everything, in great detail, complete with graphs and charts - that way if you want to treat your batteries well, all you have to do is follow the guidelines). Oh they had guidance...... but it was different in every place you found it!
I imagine what is "known" is changing, and that must be part of it, but it was still annoying. OTOH as usual their kit is spiffy and nice to work with.
Anyway, my understanding, like yours, is that they don't necessarily "want" to get up to 100% all the time like lead acid batteries prefer. And also, like you say, that the charging is basically bulk right up until it's done (no more sitting in absorb for hours!). My buddy still has a bit of "lead-acid brain," so he bought a larger bank than he probably needed. Thus, he's getting up to 100% fairly often and not discharging very deeply.
Another thing I seemed to notice in my reading is that charging recommendations for this type of lithium bank keep going down (lower bulk ending point, less absorption time, lower voltage float). Also, it has become known that they are rather sensitive to heat (that's older news though).
Between consulting with Victron, and reading what I could find elsewhere, we came up with the plan that he would set his absorb point (i.e. bulk stopping point) to (IIRC), 14.1 or 14.2, and the absorb time for one minute. (i.e. it basically gets to that point and stops). Then, once a month or so, he would let them absorb for a longer time (one or two hours, IIRC). That apparently makes sure all the cells have time to balance (again, lots of IIRC here). Obviously this means that easily adjustable chargers are key. Luckily lots of them are nowadays. He just put a reminder on his calendar.
One thing we found is that a number of chargers (especially shore chargers) don't let you lower the absorb time to basically nothing, even in custom settings. And some "lithium" settings either aren't, or seem to reflect older thinking. It was a bit easier with solar controllers to find ones that would work well. One of the issues for him is that although he had a big Magnum charger/inverter in his last setup (he changed RV's), he found that he's using much less in the way of inverter or big Peukert loads, so didn't really have a need for one. (They may tend to have more adjustability?). So he just wanted a straight shore charger (plus a modified sine wave 1500 watt stand-alone inverter for occasional use). So far there hasn't been a "right sized bear" shore charger in terms of charge settings, so he just bought a Victron portable 15 amp smart charger (he doesn't need a shore charger much) for now, figuring newer chargers would come out in time.
In a way, he doesn't really use the full advantages of lithium, since he basically runs no heavy Peukert loads (even got rid of the microwave on his new rig), and has no plans to run an AC from batteries, or etc. BUT, he has limited real estate for solar panels on the roof, and wanted to get out from under the long absorb time, plus the need to get up to 100% less often is handy. He also of course had to put in a new system on the new RV anyway (it came with two Group 24 flooded batteries, oh boy).
I would have fun setting up a lithium system in my Chinook. But at this point --- somewhat to my annoyance --- I completely don't need it. Reasons:
1) I have 375 amp hours of Lifeline AGM's. I load tested them this May and they are still over 90% health. Guess I should have been rougher on them :lol:
2) Although weight reduction is always nice, I really don't need to do that. Mine sit fairly forward, right on the frame rail, and my Concourse is not overweight. I also don't need to remove them on a regular basis (so no need to carry them around).
3) I don't tend to run a lot of heavy/Peukert type loads (no microwave, A/C, etc.). The ones I do run are infrequent and short (heat gun, vacuum, other corded tool), so I just combine and run the engine and/or do it when the batteries are full and the sun is out. No muss.
4) I'm able to get back to 100% most days via solar at this point in time.
I don't set out the list above because I'm refuting your getting them. Not at all! I just noticed some other folks thinking about it and so I thought I'd spell out why I'm not moving to them in my Chinook right now. OTOH, if my AGM's had tested unhealthy? Hmm, well then I'd have a choice on my hands. Still no NEED for ltihium, but I'd be more tempted if I were buying batteries anyway. I have also made sure than any chargers or etc. I buy are suited (not all that say they are, are, I have found -- due to charge setting limitations...)
OTOH, I still get to have fun on another vehicle I have which needs new house type batteries, on which light weight is important, and plus I remove the batteries for storage (oh my aching back). Sorry budget, you're not going to win on that one :mrgreen:
PS: Hmm, yeah, interesting thought about whether to connect house and start banks, and how, with lithium house bank. I have been thinking about that for my other (non-Chinook) project. On that one I definitely need to use the alternator (which I most often don't on my Chinook). I think I will probably be going with a Victron Buck Boost. Reason being that not only do I want to "groom" the charging profile (like with other B2B chargers), but I want to be able to limit the amount of current the lithium bank can take. The Buck Boost allows that in a setting (so for example I could only "let it" have 20 amps of charging current, or whatever). This vehicle has a small alternator, and I don't want to worry about a thirsty lithium bank putting too much strain on it. Probably not as much of an issue with a big alternator like we have on the Chinooks (depending on house bank size?). Unfortunately it's expensive due to having other features that I won't need (things like vibrate start for Sprinters vans and stuff). Before I buy I'll see if anything else suits.
I guess my impulse would always be to not connect the stock Chinook/Ford charging system to the house bank unless absolutely necessary. For me that's a few times a year, and I basically use it as "cheap bulk" charging, never expecting it to finish off the charging properly.
With a B2B it's different of course. I haven't really thought about how I would do it then (the friend I helped with the lithium system does not really have vehicle charging because it is a trailer type RV).
